[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building python swig
GRASS GIS trac at osgeo.org
Wed Sep 17 02:24:10 EDT 2008
  Reporter:  cgsbob               |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect               |      Status:  new
  Priority:  major                |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-develbranch6
Resolution:                       |    Keywords:  python swig
  Platform:  Unspecified          |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:23 hamish]:
 > One last thing I'd like to figure out before closing this bug:
 > "python test.py" should be run by the Makefile. Besides testing that it
 all works this compiles the .pyc version while we know we have write
 access to the dir. If we wait until after install and let it happen at
 runtime, it is likely that the user won't have write permissions to the
 dir and it will have to be recompiled in memory every time the user uses
 the lib.
 > For python_grass[67].py the test must be run in a fake grass session
 (same as the man pages) but I'm not sure how to do that in the Makefile.
 If you just want to compile the python_grass![67].py file, why not run a
 minimal script which simply imports that file, i.e.:
 #!/usr/bin/env python
 import python_grass7
 This won't require a dummy session.
 > For !NumPtr/build/lib.linux-i686-2.4/NumPtr.py I am not sure how to
 generalize the $ARCH.
 You can specify the directories with:
 python setup.py build --build-lib build/lib.foo --build-temp
 build/temp.foo
 Or you can calculate the directories which it will use as:
 plat_specifier = ".%s-%s" % (distutils.util.get_platform(),
 sys.version[0:3])
 lib_dir = os.path.join('build', 'lib' + plat_specifier)
 temp_dir = os.path.join('build', 'temp' + plat_specifier)
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:24>
