[GRASS-dev] Re: [GRASS GIS] #308: Compiler error while building python swig
GRASS GIS trac at osgeo.org
Wed Sep 17 04:59:56 EDT 2008
  Reporter:  cgsbob               |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect               |      Status:  closed
  Priority:  major                |   Milestone:  6.4.0
 Component:  SWIG (all bindings)  |     Version:  svn-develbranch6
Resolution:  fixed                |    Keywords:  python swig
  Platform:  Unspecified          |         Cpu:  Unspecified
Changes (by hamish):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 SWIG/python seems to be in much better shape now. Thanks for the tips.
 For kicks I tried {{{ python -O }}} to create basic optimized .pyo file
 instead of the .pyc. The resulting .pyo was binary equal to the .pyc file.
 Shrug.
 > > NumPtr
 > You can specify the directories with:
 > {{{ python setup.py build --build-lib build/lib.foo ... }}}
 done.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/308#comment:25>
