[GRASS-dev] GRASS 6.5 GEOS build fails
Martin Landa landa.martin at gmail.com
Wed Aug 26 08:46:23 EDT 2009
2009/8/26 Glynn Clements <glynn at gclements.plus.com>:
> No. Broken in r38867; fixed (i.e. reverted) in r38872.
Sorry, on my computer is broken now...
> GRASS needs GEOS 3.x; the check is supposed to fail on older versions.
geos-config --version
3.1.0
checking for geos-config... /usr/local/bin/geos-config
checking for geos_c.h... yes
checking for GEOSGeom_createLinearRing in -lgeos... no
configure: error: *** Unable to locate GEOS library.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
