[GRASS-dev] GRASS 6.5 GEOS build fails
Martin Landa landa.martin at gmail.com
Wed Aug 26 08:49:41 EDT 2009
2009/8/26 Martin Landa <landa.martin at gmail.com>:
> checking for geos-config... /usr/local/bin/geos-config
> checking for geos_c.h... yes
> checking for GEOSGeom_createLinearRing in -lgeos... no
> configure: error: *** Unable to locate GEOS library.
as I mentioned earlier it should check geos_c (i.e. GEOS C API) not geos.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
