[GRASS-dev] Re: [GRASS-SVN] r38872 - grass/trunk
Hamish hamish_b at yahoo.com
Thu Aug 27 05:42:52 EDT 2009
Glynn:
> I've committed r38878, which restores the configure checks, and adds
> adds workarounds for the issues with GEOS 2.x. Someone needs to check
> that these don't break 3.x.
great, I can report that 6.5svn now ./configures and builds --with-geos
ver 2.2.3 successfully, and that 'v.select --help' shows new options.
in related issues swig/python/ still fails to build due to too-old(?)
swig ver 1.3.29, but the ./configure check just checks for the presence
of /usr/bin/swig; it doesn't test if that contains what we need.
It would be nice if it could be made to work with older versions of swig
again, & if not, at least the ./configure script should throw an error
when --with-python is given instead of doing what it does now & fail at
compile-time.
thanks,
Hamish
