[GRASS-dev] Shell scripts
Michael Barton Michael.Barton at asu.edu
Tue Dec 1 22:42:41 EST 2009
Attached is a diff that shows how this could be done. It allows you to
type a command on the output console, hit return, and have the command
run. You can type display commands like d.rast map=elevation.dem and
have the map display in the canvas if you have auto-rendering turned on.
As Martin says, this functionality is already in the command entry
windows. I just shifted it to the output console too. There are a
couple of items that would need to be cleaned up -- hitting return in
the middle of a line sends it as a command but also breaks the line.
Also, commands entered in this way get echoed twice. But this is just
a preliminary example. It should not change any other functionality
except for permitting commands to be run from within the output console.
It should be applied to develbranch_6.
I'm not certain that I made the diff correctly (svn diff > file),
however. So you might want to look at it first, and try this on a copy.
Michael
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20091201/036be455/console_example.obj
On Dec 1, 2009, at 5:54 AM, Martin Landa wrote:
> Hi,
> 2009/12/1 Michael Barton <Michael.Barton at asu.edu>:
>> On the other hand, if these folks DO want to use the wxPython GUI
>> (and all
>> the interactive tools on the canvas) but simply want to be able to
>> get maps
>> displayed in the canvas by typing commands instead of adding them
>> to the
>> layer manager, then I think the better way to go is to enhance the
>> wxPython
>> console. This solution could be of interest to power users on all
>> platforms.
> It already works, try to type in wxGUI prompt, e.g. `d.rast
> map=elevation.dem`. Anyway I think that something like `d.mon wx0`
> would be usable.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
