[GRASS-dev] Maintenance QGIS GRASS plugin / provider
Soeren Gebbert soerengebbert at googlemail.com
Mon Dec 7 15:39:15 EST 2009
Hi Marco,
i would like to help maintaining the grass plugin in qgis.
But unfortunately i am not able to start right now. I am much to busy.
I hope to start working on it in the 2. quater of 2010.
I have curently little experience with qgis. I did not use it very often.
But i am a C/C++ and Python developer with some Qt experience and
have had a look on the grass-plugin sources. :)
Best regards
Soeren
2009/12/5 Marco Hugentobler <marco at hugis.net>:
> Dear GRASS devs
> I'm writing to you as the technical advisor of the QGIS project steering
> committee. As such, I'm trying to make sure all the parts of the program have
> a dedicated maintainer. Unfortunately, the GRASS plugin in QGIS has no
> maintainer for quite some time now.
> The GRASS plugin was written by Radim in 2004. He did a great job, maintained
> and improved the plugin successively until he left the team in 2006. Since
> then, the plugin has no maintainer. Even if there was some work on it after
> that, the GRASS plugin/provider is now the category with the most open bugs in
> the bugtracker(35).
> I think this is a pitty, because the plugin has a large user base. Especially
> (but not only) users new to GIS, are not familiar with the GRASS command line.
> So they are happy to have the QGIS GUI and the analytical power of GRASS in a
> graphical way.
> If there is someone from the GRASS community who is interested in helping to
> maintain the plugin, it would be greatly appreciated. In case of technical
> questions and problems, we are available to help.
> Best regards,
> Marco
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Webereistr. 66
> CH-8134 Zürich
> marco at hugis.net
> http://homepage.hispeed.ch/hugis/
> Technical Advisor QGIS Project Steering Committee
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
