[GRASS-dev] Re: [GRASS GIS] #838: Compile error for lib/driver
    trac at osgeo.org
    Tue Dec 15 22:37:29 EST 2009
  Reporter:  sprice   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  normal   |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-releasebranch64
Resolution:           |    Keywords:
  Platform:  MacOSX   |         Cpu:  OSX/Intel
Comment (by glynn):
 Replying to [comment:7 kyngchaos]:
 > You need to be very detailed with GRASS configure.  use both --with-libs
 and --with-includes.  That way compilation will find the right headers and
 linking will find the right libs.
 It goes beyond that. There is no (portable) way to tell the
 compiler/linker to look for a specific header/library in a specific
 directory. You specify header/library search paths with -I/-L switches,
 then all headers/libraries are located using the same search path.
 If you have multiple versions of a library installed, there may not be
 '''any''' combination of options which will make it work. Two modules
 which both use a particular library may use different combinations of
 other libraries, resulting in different combinations of -L switches,
 resulting in different versions of the first library being used.
 If you happen get into this situation, the only reliable way out of it
 (other than uninstalling stuff) is to create a dedicated header/library
 directory populated with symlinks to the desired versions, and specify
 that directory as the '''only''' additional header/library directory to be
 used.
 For the most part, it's much easier to just ensure that you don't have
 more than one version of anything. Of course, that's easier said than done
 if your OS vendor only ships versions which have been considered "stable"
 for at least three years but you need to use some FOSS package whose
 maintainers view anything over a month old as a historical relic.
Ticket URL: <http://trac.osgeo.org/grass/ticket/838#comment:8>
