[GRASS-dev] Re: a better console and better diff
Michael Barton Michael.Barton at asu.edu
Sat Dec 19 10:48:49 EST 2009
Leave it all reverted for now.
My svn broke on upgrading to OS X 10.6
I need to get that fixed so that I can commit correctly.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 19, 2009, at 8:41 AM, Martin Landa wrote:
> Hi,
> 2009/12/19 Michael Barton <Michael.Barton at asu.edu>:
>>> * completely breaks wxGUI
>> Please explain how it breaks the GUI. It tested with no issues at all on my system. If there is a bug we can work it out. Reverting without reporting the bug does not help.
> wxGUI didn't start, see error below. You committed file in a conflict.
>>>  File "/usr/local/src/grass6_devel/dist.i686-pc-linux-gnu/etc/wxpython/gui_modules/prompt.py",
>>> line 920
>>>>>>>>>> .r40052
>> It looks like all that happened was that I missed a conflict marker at the end of the file. If you remove it and try again, it should work fine.
> Yes.
>>> * re-implements GPrompt, please implement GPrompSTC without touching
>>> GPrompt (or GPromptSTC and GPromptPopUp can be subclassed from
>>> GPrompt)
>> See below
>>> * accidentally reverts my previous changes (apparently you are working
>>> with out-dated code). E.g. [1]
>> Not at all accidental. I needed to rewrite much of prompt.py to do this. Most of the code is no longer needed if we use STC, since most of it is a custom autocompletion code.
> As I mentioned earlier logging classes should go to 'goutput.py'
> module, prompt classes to 'prompt.py'. Please implement GPromptSTC
> (keep GPrompt untouched) without fundamental rewriting goutput.py.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
