[GRASS-dev] Re: [GRASS GIS] #843: v.digit broken on new WinGrass release
GRASS GIS trac at osgeo.org
Thu Dec 31 07:48:30 EST 2009
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Vector        |     Version:  unspecified
Resolution:                |    Keywords:  wingrass,v.digit
  Platform:  MSWindows XP  |         Cpu:  x86-64
Comment (by glynn):
 Replying to [comment:16 marisn]:
 > As removing something from lib/form will break backwards compatibility.
 Why does that matter? I'm fairly sure that we don't want anything else
 using lib/form, particularly F_open().
 > I attached patch that renames v.digit F_ function copies and removes
 futurer duplicate code. Worksforme, needs review.
 I'm still don't see why we can't just revert the v.digit changes and sync
 its copy of generate.c to the lib/form copy.
 I don't particularly like cloning code, but in this case the cure is worse
 than the disease.
Ticket URL: <http://trac.osgeo.org/grass/ticket/843#comment:17>
