[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4 and develbranch_6
Markus Neteler neteler at osgeo.org
Fri Mar 6 16:44:14 EST 2009
On Fri, Mar 6, 2009 at 11:52 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Colin Nielsen wrote:
>> Error 1
>> make[3]: *** No rule to make target
>> `../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
> AFAICT, this is because the rule in lib/gis/Makefile uses a path based
> upon MODULE_TOPDIR, but the compilation rules require a path relative
> to the current directory. The first attached patch should fix this part.
> The second patch should fix the issue with lib/datetime being built
> before lib/gis. If it doesn't, just try running "make" a second time
> without an intervening "make clean".
I have merged that into a revised patch in
http://trac.osgeo.org/grass/ticket/519
Colin, could you please try that?
Further doubts in the ticket.
Markus
