[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4 and develbranch_6
Colin Nielsen colin.nielsen at gmail.com
Sat Mar 7 09:23:41 EST 2009
I applied the patches and recompiled. Still lots of errors I'm afraid.
I've attached the make errors.
The first major error is with lib/gis
-Colin
On 3/6/09, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Mar 6, 2009 at 11:52 AM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Colin Nielsen wrote:
>>> Error 1
>>> make[3]: *** No rule to make target
>>> `../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
>> AFAICT, this is because the rule in lib/gis/Makefile uses a path based
>> upon MODULE_TOPDIR, but the compilation rules require a path relative
>> to the current directory. The first attached patch should fix this part.
>> The second patch should fix the issue with lib/datetime being built
>> before lib/gis. If it doesn't, just try running "make" a second time
>> without an intervening "make clean".
> I have merged that into a revised patch in
> http://trac.osgeo.org/grass/ticket/519
> Colin, could you please try that?
> Further doubts in the ticket.
> Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090307/88362188/make-0001.obj
