[GRASS-dev] wxversion checking does not work with bundled wxpython
William Kyngesburye woklist at kyngchaos.com
Sun Mar 8 21:05:29 EDT 2009
I was looking into the possibility of bundling a slimmed-down wxpython
into the OSX application package and ran into a problem.  It appears
that wxversion.select() does not work with a bundled wxpython.  From
the wxversion docstring:
   NOTE: If you are making a 'bundle' of your application with a tool
   like py2exe then you should *not* use the wxversion module since it
   looks at the filesystem for the directories on sys.path, it will fail
   in a bundled environment.  Instead you should simply ensure that the
   version of wxPython that you want is found by default on the sys.path
   when making the bundled version by setting PYTHONPATH.  Then that
   version will be included in your bundle and your app will work as
   expected.
I suggest changing the CheckForWx() line in globalvar.py, and a bunch
of others, to:
if not os.getenv("GRASS_WXBUNDLED"):
     CheckForWx()
Then I can set PYTHONPATH and GRASS_WXBUNDLED and the wx gui will use
the bundled wxpython.  (tested and it works)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
