[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4 and develbranch_6
Colin Nielsen colin.nielsen at gmail.com
Mon Mar 9 09:51:50 EDT 2009
>> (As usual with mingw, only the lidar modules fail.)
The lidar module problems have been around for a while now
(http://grass.osgeo.org/wiki/WinGRASS_Current_Status).
I've attached the errors for the r.li dir.
> Please check if the remaining 4-5 patches in
> http://trac.osgeo.org/grass/ticket/519
> are necessary.
I could be wrong, but it looks like the lidar part of the patch has
caused two attempts to make r.li. Each module in r.li.* has two
entries in error.log.
I'm not sure what the gdal patch does, but I did have some problems
getting gdal working in the past (I can't remember exactly what the
problem was), so perhaps this has fixed that. And likewise, xdr has
apparently been a problem under mingw as well
(http://lists.osgeo.org/pipermail/grass-windows/2008-December/001611.html).
spawn and g3d I have no idea, but from my make.log
C:/MinGW/msys/local/src/grass-6.4_release/dist.i686-pc-mingw32/include/grass/gis.h:48:1:
warning: this is the location of the previous definition
spawn.c: In function `G_spawn':
spawn.c:84: warning: passing arg 3 of `_spawnv' from incompatible pointer type
spawn.c: In function `do_spawn':
spawn.c:234: warning: passing arg 3 of `spawnvpe' from incompatible pointer type
spawn.c:234: warning: passing arg 4 of `spawnvpe' from incompatible pointer type
I think that's all I can offer at this point. I'm sure jef can clear
up the last details.
-Colin
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090309/4d7fe0d2/lidar-0001.obj
