[GRASS-dev] location wizard borked
    Martin Landa
    landa.martin at gmail.com
    Tue Mar 10 06:54:50 EDT 2009
2009/3/10 Vincent Bain <bain at toraval.fr>:
> related to the location wizard, perhaps what follows does not deal with
> any sort of bug but my misuse of the location creation process :
> If you need to create from scratch a new gisdabe, located elsewhere than
> the current one, the location wizard first writes your new location
> directory in the /current/ gisdbase instead of the new one you've just
> set. Then when you define a new mapset or want to start from within
> PERMANENT, the application fails, with this message :
seems to work for me.
1. Create new directory for gisdbase (e.g. $HOME/grassdata1) - mkdir
2. Choose gisdbase
3. Run location wizard
4. New location created in $HOME/grassdata1
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
