[GRASS-dev] osgeo4w on Windows Vista: g.proj.exe crashes when setting the initial location
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Mar 10 14:00:18 EDT 2009
On Tue, 10 Mar 2009, G. Allegri wrote:
> Hello list.
> I've just setup grass from osgeo4w. I'm a Linux user but I need to
> develop some grass scripts on windows.
> When launching it from grass64.bat as tcltk iface, I obtain the
> classic prompt for location. I try to set it from EPSG codes but when
> I've choosen the name and the code, g.proj.exe crashes with a
> "segmentation violation"
> I'm working on Windows Vista SP1.
Can you give an example g.proj command-line that reproduces the problem?
Do other uses of g.proj also crash?
Paul
