[GRASS-dev] osgeo4w on Windows Vista: g.proj.exe crashes when setting the initial location
G. Allegri giohappy at gmail.com
Tue Mar 10 19:08:32 EDT 2009
I've tried from the osgeo4w shell, after setting GISRC and GRASS_GUI
manually, launching:
g.proj.exe -c epsg=4326 location=WGS84
It happens the same as with the tcltk interface... just a not better
specified crash.
2009/3/10 Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> On Tue, 10 Mar 2009, G. Allegri wrote:
>> Hello list.
>> I've just setup grass from osgeo4w. I'm a Linux user but I need to
>> develop some grass scripts on windows.
>> When launching it from grass64.bat as tcltk iface, I obtain the
>> classic prompt for location. I try to set it from EPSG codes but when
>> I've choosen the name and the code, g.proj.exe crashes with a
>> "segmentation violation"
>> I'm working on Windows Vista SP1.
> Can you give an example g.proj command-line that reproduces the problem?
> Do other uses of g.proj also crash?
> Paul
