[GRASS-dev] running v.surf.rst from GUI
Martin Landa landa.martin at gmail.com
Fri Mar 13 03:55:37 EDT 2009
2009/3/13 Helena Mitasova <hmitaso at unity.ncsu.edu>:
> Inputs   Outputs   Parameters
> and Markus is right - guisection is missing for elev, it should be added
> here
> 189     parm.elev->description = _("Output surface raster map (elevation)");
> parm.elev->guisection = _("Output_options");
> and for maskmap as well (that should be under Inputs tab)
> If you could change this it would be great (I won't have time until weekend
> to
> do something about it)
done in GRASS 7 (r36353). In no objections I will backported it to
devbr6/relbr64.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
