[GRASS-dev] lib/vector/Vlib/*.c: Too much uses of `GRASS_VECT_DIRECTORY'
Ivan Shmakov oneingray at gmail.com
Sun Mar 22 08:43:58 EDT 2009
	May I suggest the change below?
	Basically, this one introduces three tiny new functions to be
	used instead of coding the construction of the vector
	map-related filenames explicitly.  Like:
-   sprintf (buf, "%s/%s", GRASS_VECT_DIRECTORY, map_info->name);
+   Vect_map_file_name_rel (buf, map_info);
	I wasn't sure where to declare these functions, so I've added
	the prototypes to `include/Vect.h'.
Index: include/Vect.h
--- include/Vect.h	(revision 36440)
+++ include/Vect.h	(working copy)
@@ -218,6 +218,13 @@
 int Vect_rewind(struct Map_info *);
 int Vect_close(struct Map_info *);
+/* filenames */
+int Vect_map_file_name_rel (char [GPATH_MAX], const struct Map_info *);
+int Vect_map_element_file_name_rel (char [GPATH_MAX],
+				    const struct Map_info *, const char *);
+int Vect_map_element_file_name_abs (char [GPATH_MAX],
 /* Read/write lines, nodes, areas */
 /* Level 1 and 2 */
 int Vect_read_next_line(struct Map_info *, struct line_pnts *,
Index: lib/vector/Vlib/file_name.c
--- lib/vector/Vlib/file_name.c	(revision 0)
+++ lib/vector/Vlib/file_name.c	(revision 0)
@@ -0,0 +1,48 @@
+   \file file_name.c
+   \brief GIS library - Determine GRASS data base / vector file name
+   (C) 2009 by the GRASS Development Team
+   This program is free software under the GNU General Public License as
+   published by the Free Software Foundation; either version 2 of the
+   License, or (at your option) any later version.
+   Read the file COPYING that comes with GRASS
+   for details.
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+int
+Vect_map_file_name_rel (char result[GPATH_MAX],
+                        const struct Map_info *map)
+    return
+        sprintf (result, "%s/%s",
+                 GRASS_VECT_DIRECTORY, map->name);
+int
+Vect_map_element_file_name_rel (char result[GPATH_MAX],
+                                const struct Map_info *map,
+                                const char *element)
+    return
+        sprintf (result, "%s/%s/%s",
+                 GRASS_VECT_DIRECTORY, map->name, element);
+int
+Vect_map_element_file_name_abs (char result[GPATH_MAX],
+    return
+        sprintf (result, "%s/%s/%s/%s/%s/%s",
+                 map->gisdbase, map->location, map->mapset,
Index: lib/vector/Vlib/build.c
--- lib/vector/Vlib/build.c	(revision 36440)
+++ lib/vector/Vlib/build.c	(working copy)
@@ -247,7 +247,7 @@
     plus = &(Map->plus);
     /*  write out all the accumulated info to the plus file  */
-    sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+    Vect_map_file_name_rel (buf, Map);
     G__file_name(fname, buf, GV_TOPO_ELEMENT, Map->mapset);
     G_debug(1, "Open topo: %s", fname);
     dig_file_init(&fp);
@@ -398,7 +398,7 @@
     /*  write out rtrees to the sidx file  */
     G__file_name(fname, buf, GV_SIDX_ELEMENT, Map->mapset);
     G_debug(1, "Open sidx: %s", fname);
     dig_file_init(&fp);
Index: lib/vector/Vlib/close.c
--- lib/vector/Vlib/close.c	(revision 36440)
+++ lib/vector/Vlib/close.c	(working copy)
@@ -77,7 +77,7 @@
 	struct stat info;
 	/* Delete old support files if available */
 	G__file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
 	if (stat(file_path, &info) == 0)	/* file exists? */
Index: lib/vector/Vlib/open_nat.c
--- lib/vector/Vlib/open_nat.c	(revision 36440)
+++ lib/vector/Vlib/open_nat.c	(working copy)
@@ -49,7 +49,7 @@
     G_debug(1, "V1_open_old_nat(): name = %s mapset = %s", Map->name,
 	    Map->mapset);
     dig_file_init(&(Map->dig_fp));
     if (update)
 	Map->dig_fp.file = G_fopen_modify(buf, GRASS_VECT_COOR_ELEMENT);
Index: lib/vector/Vlib/close_ogr.c
--- lib/vector/Vlib/close_ogr.c	(revision 36440)
+++ lib/vector/Vlib/close_ogr.c	(working copy)
@@ -73,7 +73,7 @@
     if (strcmp(Map->mapset, G_mapset()) == 0 && Map->support_updated &&
 	Map->plus.built == GV_BUILD_ALL) {
-	sprintf(elem, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+	Vect_map_file_name_rel (elem, Map);
 	G__file_name(fname, elem, "fidx", Map->mapset);
 	G_debug(4, "Open fidx: %s", fname);
 	dig_file_init(&fp);
Index: lib/vector/Vlib/cindex.c
--- lib/vector/Vlib/cindex.c	(revision 36440)
+++ lib/vector/Vlib/cindex.c	(working copy)
@@ -451,7 +451,7 @@
     G__file_name(fname, buf, GV_CIDX_ELEMENT, Map->mapset);
     G_debug(2, "Open cidx: %s", fname);
     dig_file_init(&fp);
@@ -497,7 +497,7 @@
     Plus = &(Map->plus);
     G__file_name(file_path, buf, GV_CIDX_ELEMENT, Map->mapset);
     if (stat(file_path, &info) != 0)	/* does not exist */
Index: lib/vector/Vlib/open_ogr.c
--- lib/vector/Vlib/open_ogr.c	(revision 36440)
+++ lib/vector/Vlib/open_ogr.c	(working copy)
@@ -122,7 +122,7 @@
     G_debug(3, "V2_open_old_ogr()");
     dig_file_init(&fp);
     fp.file = G_fopen_old(elem, "fidx", Map->mapset);
     if (fp.file == NULL) {
Index: lib/vector/Vlib/field.c
--- lib/vector/Vlib/field.c	(revision 36440)
+++ lib/vector/Vlib/field.c	(working copy)
@@ -603,9 +603,7 @@
 		      Map->format);
-    sprintf(file, "%s/%s/%s/%s/%s/%s", Map->gisdbase, Map->location,
-	    Map->mapset, GRASS_VECT_DIRECTORY, Map->name,
-	    GRASS_VECT_DBLN_ELEMENT);
+    Vect_map_element_file_name_abs (file, Map, GRASS_VECT_DBLN_ELEMENT);
     G_debug(1, "dbln file: %s", file);
     fd = fopen(file, "r");
@@ -676,9 +680,7 @@
     dbl = Map->dblnk;
     fd = fopen(file, "w");
Index: lib/vector/Vlib/header.c
--- lib/vector/Vlib/header.c	(revision 36440)
+++ lib/vector/Vlib/header.c	(working copy)
@@ -88,7 +88,7 @@
     char buf[200];
     FILE *head_fp;
     head_fp = G_fopen_new(buf, GRASS_VECT_HEAD_ELEMENT);
     if (head_fp == NULL) {
@@ -137,7 +137,7 @@
     Vect_set_thresh(Map, 0.);
     G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
-    sprintf(buff, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+    Vect_map_file_name_rel (buff, Map);
     head_fp = G_fopen_old(buff, GRASS_VECT_HEAD_ELEMENT, Map->mapset);
 	G_warning(_("Unable to open header file of vector <%s>"),
FSF associate member #7257
