[GRASS-dev] GRASS 7 configure fails on Mac
William Kyngesburye woklist at kyngchaos.com
Mon Mar 30 15:00:42 EDT 2009
Ah.  I guess you could do similar to how the other frameworks are
handled:
--with-geos-includes=/Library/Frameworks/GEOS.framework/unix/include --
with-geos-libs=/Library/Frameworks/GEOS.framework/unix/lib
-OR-
--with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config
depending on how configure is setup to handle GEOS.
On Mar 30, 2009, at 1:38 PM, Martin Landa wrote:
> Hi,
> 2009/3/30 Michael Barton <michael.barton at asu.edu>:
>> I just did an svn update from trunk and tried to configure GRASS 7
>> prior to
>> compiling. I'm using the same configure string that worked
>> successfully 48
>> hours ago. But configure failed with an geos-config error (below).
>> Is this a
>> bug, or do I need to change my config string to something different?
> recently geos supported was added, so you need to install GEOS library
> or configure with --with-geos=no.
> M.
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
