[GRASS-dev] GRASS 7 configure fails on Mac
William Kyngesburye woklist at kyngchaos.com
Tue Mar 31 09:39:32 EDT 2009
The problem is not that geos_c.h is missing, it's that the vdigit
makefile needs the geos include path in its EXTRA_CFLAGS.
The vlib compile does include this, as a part of VECT_CFLAGS, thus
it's not failing.
On Mar 31, 2009, at 12:02 AM, Martin Landa wrote:
> Hi,
> 2009/3/31 Michael Barton <michael.barton at asu.edu>:
>> So you're saying that vdigit doesn't work again because of the geos
>> problem?
> again, problem? ;-)
> I wasn't expecting that if you have GEOS installed that geos_c.h is
> not available. If so than vector libs compilation fail. In this case
> checking for geos-config is not enough.
> M.
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
