[GRASS-dev] python grass problems on OSX (Incompatible library version for module)
massimo di stefano massimodisasha at yahoo.it
Mon May 11 02:02:17 EDT 2009
Hi Glynn, All,
Il giorno 11/mag/09, alle ore 03:32, Glynn Clements ha scritto:
> massimo di stefano wrote:
>> i'm tring to utilize a python function iside the grass environment,
>> but i gett errors about :
>> "Incompatible library version for module"
> If "make clean" and rebuilding doesn't fix it, then it sounds like you
> have more than one version of GRASS on your system, and it's picking
> up the wrong libraries.
Yes it is, i tried make clean && make distclean,
i also tried on a fresh svn download.
I've installed on my system different grass versions :
grass64 (binary verion)
grass65 , grass70  (from svn)
>> outside a running GRASS, it works from python.  From python started
>> inside a GRASS shell, it doesn't work.
> That sounds like multiple versions.
How to avoid this problem?
has my system hardcoded some where the existence oh other grss
version? can i masherate/eliminate something?
>> the function i'm using is prety simple :
>> import os
>> import subprocess
>> def OssimImg2rr(img1):
>>     os.environ['DYLD_FRAMEWORK_PATH'] = '/var/tmp/XcodeBuilds/
>> Release'
>>     os.environ['OSSIM_PREFS_FILE'] = '/Users/sasha/ossim_preferences'
>>     output = subprocess.Popen(['/var/tmp/XcodeBuilds/Release/
>> img2rr' ,str(img1)],stdout=subprocess.PIPE).communicate()[0]
> Leave os.environ alone; create a new environment dictionary and pass
> that to subprocess.Popen(), e.g.:
> 	myenv = os.environ.copy()
> 	myenv['DYLD_FRAMEWORK_PATH'] = '/var/tmp/XcodeBuilds/Release'
> 	myenv['OSSIM_PREFS_FILE'] = '/Users/sasha/ossim_preferences'
> 	output = subprocess.Popen(..., env = myenv).communicate()[0]
> This isn't related to this specific problem, though, just general
> Python coding advice.
Thanks! i'm self.teached so advice like these ere for me a great help
i hope i modified it well :
img2rr' ,str(img1)], stdout=subprocess.PIPE, env = myenv).communicate()
[0]
Massimo Di Stefano
massimodisasha a yahoo.it
epifanio on   irc.freenode.net  /join gfoss
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
