[GRASS-dev] python grass problems on OSX (Incompatible library version for module)
William Kyngesburye woklist at kyngchaos.com
Mon May 11 10:18:09 EDT 2009
On May 11, 2009, at 1:02 AM, massimo di stefano wrote:
>>> outside a running GRASS, it works from python.  From python started
>>> inside a GRASS shell, it doesn't work.
>> That sounds like multiple versions.
> How to avoid this problem?
> has my system hardcoded some where the existence oh other grss
> version? can i masherate/eliminate something?
Build them as Mac applications, and they won't interfere with each
other.  See the source macosx readme.  Though even as a unix build
they shouldn't, since each is in a self-contained version-named folder.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
