[GRASS-dev] Re: [GRASS GIS] #604: /usr/lib/grass64/etc/grass-run.sh does not work properly when called by gis.m to execute in a external xterm
GRASS GIS trac at osgeo.org
Wed May 20 09:10:43 EDT 2009
  Reporter:  frankie   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  Tcl       |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  xterm
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by hamish):
 ... the next challenge is to get the main wxGUI `Cmd >` command-line
 prompt to successfully run this command on both UNIX & DOS versions.
   v.db.select roads where="label ~ 'highway'"
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/604#comment:22>
