[GRASS-dev] [GRASS GIS] #814: r.resamp.stats memory corruption when resampling from different projection/zone
GRASS GIS trac at osgeo.org
Wed Nov 18 18:18:34 EST 2009
projection/zone
 Reporter:  pertusus  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.0
Component:  Raster    |     Version:  6.4.0 RCs
 Keywords:            |    Platform:  Linux
      Cpu:  x86-32    |
 I would like to resample a map from a mapset to another that have a
 different region using r.resamp.stats -w
 In the new mapset, CRU_GRID, region is:
  > g.region -p
 projection: 3 (Latitude-Longitude)
 zone:       0
 datum:      ** unknown (default: WGS84) **
 ellipsoid:  sphere
 north:      90N
 south:      90S
 west:       180W
 east:       180E
 nsres:      0:30
 ewres:      0:30
 rows:       360
 cols:       720
 cells:      259200
 In the PERMANENT mapset, the region is:
  > g.region -p
 projection: 99 (Lambert Azimuthal Equal Area)
 zone:       0
 ellipsoid:  sphere
 north:      4149500
 south:      -5044500
 west:       -4368500
 east:       4367500
 nsres:      1000
 ewres:      1000
 rows:       9194
 cols:       8736
 cells:      80318784
 The map is a normal raster map in the PERMANENT mapset:
  > r.info one_up_basin_194
  | Layer:    one_up_basin_194               Date: Wed Nov 18 18:41:41 2009
  | Mapset:   PERMANENT                      Login of Creator: dumas
  | DataBase: /home/dumas/maps
  | Title:     ( one_up_basin_194 )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 1
  |   Data Type:    CELL
  |   Rows:         3996
  |   Columns:      1830
  |   Total Cells:  7312680
  |        Projection: Lambert Azimuthal Equal Area
  |            N:    2969500    S:   -1026500   Res:  1000
  |            E:    2189500    W:     359500   Res:  1000
  |   Range of data:    min = 1  max = 1
  |   Data Description:
  |    generated by r.mapcalc
  |   Comments:
  |    if(isnull(up_basin_194), 1 / 0, 1)
  > r.stats -c one_up_basin_194
  100%
 1 866152
 * 79452632
 When in the CRU_GRID mapset I try to resample the map from the PERMANENT
 mapset, I get an error message, and glibc detects some memory corruption:
  > r.resamp.stats -w input=one_up_basin_194 at PERMANENT
 output=one_up_basin_194
 WARNING: G_set_window(): projection/zone differs from that of currently
          open raster maps
 *** glibc detected *** r.resamp.stats: malloc(): memory corruption (fast):
 0x081725f8 ***
 ======= Backtrace: =========
 /lib/libc.so.6[0x658ba9]
 /lib/libc.so.6(__libc_malloc+0x67)[0x659d87]
 /usr/lib/libgrass_gis.so.6.4(G__malloc+0x2a)[0xeca82a]
 /usr/lib/libgrass_gis.so.6.4(G__location_path+0x5c)[0xee416c]
 /usr/lib/libgrass_gis.so.6.4(G__file_name+0x3f)[0xed936f]
 /usr/lib/libgrass_gis.so.6.4[0xed99f2]
 /usr/lib/libgrass_gis.so.6.4[0xed9aca]
 /usr/lib/libgrass_gis.so.6.4(G_find_cell+0x2e)[0xed954e]
 /usr/lib/libgrass_gis.so.6.4(G__check_for_auto_masking+0x4b)[0xecc72b]
 /usr/lib/libgrass_gis.so.6.4(G_set_window+0x164)[0xefae44]
 r.resamp.stats(main+0x10c3)[0x804a453]
 /lib/libc.so.6(__libc_start_main+0xdc)[0x603e9c]
 r.resamp.stats(w_var+0xa5)[0x80492d1]
 ======= Memory map: ========
 00176000-00177000 r-xp 00176000 00:00 0          [vdso]
 0019b000-0019f000 r-xp 00000000 08:01 1368258
 /usr/lib/libgrass_stats.so.6.4.0RC5
 0019f000-001a0000 rwxp 00003000 08:01 1368258
 003b1000-003cb000 r-xp 00000000 08:01 834029     /lib/ld-2.5.so
 003cb000-003cc000 r-xp 00019000 08:01 834029     /lib/ld-2.5.so
 003cc000-003cd000 rwxp 0001a000 08:01 834029     /lib/ld-2.5.so
 00539000-0054b000 r-xp 00000000 08:01 1367055    /usr/lib/libz.so.1.2.3
 0054b000-0054c000 rwxp 00011000 08:01 1367055    /usr/lib/libz.so.1.2.3
 005ee000-0072d000 r-xp 00000000 08:01 834042     /lib/libc-2.5.so
 0072d000-0072f000 r-xp 0013f000 08:01 834042     /lib/libc-2.5.so
 0072f000-00730000 rwxp 00141000 08:01 834042     /lib/libc-2.5.so
 00730000-00733000 rwxp 00730000 00:00 0
 0077a000-00782000 r-xp 00000000 08:01 1366008
 /usr/lib/libgrass_datetime.so.6.4.0RC5
 00782000-00783000 rwxp 00007000 08:01 1366008
 009f0000-009fb000 r-xp 00000000 08:01 833980
 /lib/libgcc_s-4.1.2-20080825.so.1
 009fb000-009fc000 rwxp 0000a000 08:01 833980
 00b4e000-00b73000 r-xp 00000000 08:01 834068     /lib/libm-2.5.so
 00b73000-00b74000 r-xp 00024000 08:01 834068     /lib/libm-2.5.so
 00b74000-00b75000 rwxp 00025000 08:01 834068     /lib/libm-2.5.so
 00ebd000-00f10000 r-xp 00000000 08:01 1367259
 /usr/lib/libgrass_gis.so.6.4.0RC5
 00f10000-00f11000 rwxp 00053000 08:01 1367259
 00f11000-00f18000 rwxp 00f11000 00:00 0
 00f5f000-00f61000 r-xp 00000000 08:01 834062     /lib/libdl-2.5.so
 00f61000-00f62000 r-xp 00001000 08:01 834062     /lib/libdl-2.5.so
 00f62000-00f63000 rwxp 00002000 08:01 834062     /lib/libdl-2.5.so
 08048000-0804b000 r-xp 00000000 08:01 182315
 /usr/lib/grass-6.4.0RC5/bin/r.resamp.stats
 0804b000-0804c000 rw-p 00002000 08:01 182315
 08170000-08191000 rw-p 08170000 00:00 0          [heap]
 b7c00000-b7c21000 rw-p b7c00000 00:00 0
 b7c21000-b7d00000 ---p b7c21000 00:00 0
 b7d2c000-b7f2c000 r--p 00000000 08:01 1373566    /usr/lib/locale/locale-
 archive
 b7f2c000-b7f2e000 rw-p b7f2c000 00:00 0
 b7f43000-b7f44000 r--p 02b73000 08:01 1373566    /usr/lib/locale/locale-
 archive
 b7f44000-b7f45000 rw-p b7f44000 00:00 0
 bfa49000-bfa5e000 rw-p bffea000 00:00 0          [stack]
 Abandon
Ticket URL: <http://trac.osgeo.org/grass/ticket/814>
