[GRASS-dev] Re: [GRASS GIS] #814: r.resamp.stats memory corruption when resampling from different projection/zone
GRASS GIS trac at osgeo.org
Thu Nov 19 04:59:44 EST 2009
projection/zone
  Reporter:  pertusus  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:
  Platform:  Linux     |         Cpu:  x86-32
Comment (by pertusus):
 Replying to [comment:1 glynn]:
 > Whoa. This shouldn't be possible. Projections are per-location, not per-
 mapset. I suggest running
 > g.region -d
 > in both mapsets, then trying again.
 Ok, I indeed did wrong. After g.region -d in CRU_GRID the region from the
 PERMANENT is reused in the mapset and indeed it works (but does nothing,
 and certainly doesn't do what I want to...).
 > I'm curious as to how you ended up with a WIND file with a different
 projection than the DEFAULT_WIND file. If it's because you copied a mapset
 directory from one location to another, the answer is "don't do that".
 I do this all the time to start a new location, I didn't find another way
 to do it not manually (I have a location with only PERMANENT with only
 DEFAULT_WIND  PROJ_INFO  PROJ_UNITS  WIND
 and I copy it). And I also did it in that case, I took those files from a
 different location and put them in the mapset... I found it a bit
 cumbersome, but I thought that it was the only way to be able to do what I
 want to. Looks like I was wrong, if mapsets have to share a projection,
 then, indeed, I am still missing something. Back to the documentation, I
 guess.
 In any case the memory corruption is certainly something to fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/814#comment:2>
