[GRASS-dev] v.outlier
helena hmitaso at unity.ncsu.edu
Sun Nov 22 00:46:33 EST 2009
this is an issue that may be related to the v.surf.bspline #96 bug.
When running v.outlier on 3D vector file with topology built but no
DBF table
we get the following error:
v.outlier input=JR2007 output=JR2007_outlierfree
outlier=JR2007_outliers thres_o=30
DBMI-DBF driver error:
Table 'Auxiliar_outlier_table' doesn't exist.
Error in db_execute_immediate()
ERROR: Impossible to write in the database
The output files are actually written but when trying to display them
we get
GRASS 6.4.0RC5 (nc_spm_08):~/tgrassdata > d.vect JR2007_outlierfree
siz=1 co=red
WARNING: Coor files of vector map <JR2007_outlierfree at helena> is larger
          than it should be (94411739 bytes excess)
WARNING: Unable to display areas, topology not available
Segmentation fault
GRASS 6.4.0RC5 (nc_spm_08):~/tgrassdata > d.vect JR2007_outliers siz=1
co=red
WARNING: Coor files of vector map <JR2007_outliers at helena> is larger
than
          it should be (839 bytes excess)
Looking at the manual it seems that the table is needed only for QGIS
output where
the elevation is stored as category. So I am wondering whether this
is  a bug
that needs to be fixed or whether the v.* lidar modules require points
with elevation stored in DBF (which is a problem for large datasets) -
if that is
the case it should be probably mentioned in the man page.
These modules would be really useful if we could get them to work,
Helena
On Nov 21, 2009, at 11:27 AM, GRASS GIS wrote:
> #96: v.surf.bspline column option broken
>  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
>      Type:  defect    |      Status:  reopened
>  Priority:  major     |   Milestone:  6.4.0
> Component:  Raster    |     Version:  unspecified
> Resolution:            |    Keywords:  v.surf.bspline
>  Platform:  All       |         Cpu:  All
> Comment (by cmbarton):
> Forgot to give an example of the command I used--that did not work.
> Michael
> v.surf.bspline --overwrite input=elev_pts1000_sql at sqlite_test
> raster=aaa_splintest at sqlite_test sie=400 sin=400 layer=1
> column=elevation
> Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:13>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
