[GRASS-dev] v.outlier
Maris Nartiss maris.gis at gmail.com
Sun Nov 22 04:52:15 EST 2009
Hello Helena,
no. v.outlier issues are not related to v.surf.bspline DBF problems.
v.surf.bspline has some hairy code and thus I was not trying to fix it
- to not broke something by accident.
v.outlier is different. Open a trac request to remove database
dependency for it. Current code allover manipulates with database and
it will require some work to make database manipulation optional.
Also on error it should not leave unfinished vector files on disk.
Also having QGIS as an output option should be renamed to reveal this
options output content as it migh be usefull also for other GUIs not
only QGIS.
Maris.
2009/11/22, helena <hmitaso at unity.ncsu.edu>:
> this is an issue that may be related to the v.surf.bspline #96 bug.
> When running v.outlier on 3D vector file with topology built but no
> DBF table
> we get the following error:
> v.outlier input=JR2007 output=JR2007_outlierfree
> outlier=JR2007_outliers thres_o=30
> DBMI-DBF driver error:
> Table 'Auxiliar_outlier_table' doesn't exist.
> Error in db_execute_immediate()
> ERROR: Impossible to write in the database
> The output files are actually written but when trying to display them
> we get
> GRASS 6.4.0RC5 (nc_spm_08):~/tgrassdata > d.vect JR2007_outlierfree
> siz=1 co=red
> WARNING: Coor files of vector map <JR2007_outlierfree at helena> is larger
>           than it should be (94411739 bytes excess)
> WARNING: Unable to display areas, topology not available
> Segmentation fault
> GRASS 6.4.0RC5 (nc_spm_08):~/tgrassdata > d.vect JR2007_outliers siz=1
> co=red
> WARNING: Coor files of vector map <JR2007_outliers at helena> is larger
> than
>           it should be (839 bytes excess)
> Looking at the manual it seems that the table is needed only for QGIS
> output where
> the elevation is stored as category. So I am wondering whether this
> is  a bug
> that needs to be fixed or whether the v.* lidar modules require points
> with elevation stored in DBF (which is a problem for large datasets) -
> if that is
> the case it should be probably mentioned in the man page.
> These modules would be really useful if we could get them to work,
> Helena
> On Nov 21, 2009, at 11:27 AM, GRASS GIS wrote:
>> #96: v.surf.bspline column option broken
>>  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
>>      Type:  defect    |      Status:  reopened
>>  Priority:  major     |   Milestone:  6.4.0
>> Component:  Raster    |     Version:  unspecified
>> Resolution:            |    Keywords:  v.surf.bspline
>>  Platform:  All       |         Cpu:  All
>> Comment (by cmbarton):
>> Forgot to give an example of the command I used--that did not work.
>> Michael
>> v.surf.bspline --overwrite input=elev_pts1000_sql at sqlite_test
>> raster=aaa_splintest at sqlite_test sie=400 sin=400 layer=1
>> column=elevation
>> Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:13>
>> GRASS GIS <http://grass.osgeo.org>
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
