[GRASS-dev] grass/wx 6.4 problems on Debian sid.
Martin Landa landa.martin at gmail.com
Wed Oct 7 09:46:40 EDT 2009
2009/10/7 Francesco P. Lovergine <frankie at debian.org>:
> swig 1.3.39 instead of 1.3.36
> wxpython 2.8.7 instead of 2.8.10
> I suspect the main problem is swig, due to past experiences. What are
> the reference versions suggested currently? I would suggest to
> distribute swig generated stuff by default and allowing re-building
> on demand. That solved various swig-related problems in the past.
yes, downgrade to swig 1.3.36 helps. I hope to have more time to dig
into the problem.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
