[GRASS-dev] svn help
Martin Landa
landa.martin at gmail.com
Tue Oct 13 06:39:17 EDT 2009
2009/10/13 Jarosław Jasiewicz <jarekj at amu.edu.pl>:
> BTW... I wrote r.stream.del module base on r.stream.basins code (i.e I
> copied r.stream.basin to r.stram.del and modified the code. It is the only
> relationship between that two modules.
you probably copied also metadata dictionary (.svn). It could be the
reason. The best way to fork a module is to use 'svn copy' otherwise
logs are broken.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
