[GRASS-dev] suspicious warnings while compiling GRASS trunk (r39080)
Markus Neteler neteler at osgeo.org
Sun Sep 13 03:57:53 EDT 2009
On Sun, Sep 13, 2009 at 1:32 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> I have backported the relevant changes but I am unsure about
>> r39134, Attempt to determine message encoding on Windows [relevant for R]
> I think that this should be back-ported. Otherwise, I can't see
> --with-nls working on Windows, as --interface-description will
> generate invalid XML.
Ok, done (6.4 and 6.5).
>> r39136, Fix diglib warnings
> These mostly fix warnings related to Markus Metz' LFS changes, so
> shouldn't be applicable to 6.4.
