[GRASS-dev] Re: [GRASS GIS] #757: WinGRASS: GUI window from cmd line
GRASS GIS trac at osgeo.org
Tue Sep 22 15:56:14 EDT 2009
  Reporter:  silviap       |       Owner:  grass-dev at lists.osgeo.org
      Type:  task          |      Status:  new
  Priority:  trivial       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  6.4.0 RCs
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by silviap):
 Replying to [comment:7 cnielsen]:
 > A bit of misunderstanding here. GRASS is starting fine, but once open
 the dialogs of individual modules aren't opening when they are typed into
 the shell. Instead if you type {{{ r.walk }}} or whatever, the module's
 ascii help text is output to the shell (as required arguments are missing,
 ie. output) instead of opening a dialog window where the arguments may be
 > -Colin
 GRASS is starting fine, thank you for explaining it better and sorry for
 creating the misunderstanding.
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:8>
