[GRASS-dev] Rast_set_window() changes in 7.0
Seth Price seth at pricepages.org
Sat Aug 14 02:57:20 EDT 2010
I'm getting an error whenever I run r.sun under the latest weekly:
ERROR: Output window changed while maps are open for write
Here's the command I'm using:
r.sun numpartitions=2 elevin=gauss glob_rad=glob_rad_out day=180
Is this related to your work? Should I make a bug report?
~Seth
On Jul 22, 2010, at 12:57 AM, Glynn Clements wrote:
> r42876 implements a fairly invasive change to the raster window
> handling in 7.0. Specifically:
> 1. Modules which read and write maps at different resolutions now make
> use of the ability to set separate input and output windows
> (Rast_set_input_window() and Rast_set_output_window()).
> 2. Changing the input/output window while maps are open for read/write
> (respectively) now generates a fatal error. There should be no need to
> do so, and I want to get bug reports for any cases I've overlooked.
> Rast_set_window() changes both the input and output windows.
> I would appreciate it if people can test any affected modules.
> Specifically, the following are the modules and libraries which called
> Rast_set_window:
> 	display/d.rast.arrow
> 	display/d.rast.num
> 	general/g.region
> 	imagery/i.atcorr
> 	imagery/i.ifft
> 	imagery/i.rectify
> 	lib/display
> 	lib/gpde
> 	lib/lidar
> 	lib/rst/interp_float
> 	ps/ps.map
> 	raster/r.basins.fill
> 	raster/r.category
> 	raster/r.coin
> 	raster/r.compress
> 	raster/r.describe
> 	raster/r.external
> 	raster/r.flow
> 	raster/r.horizon
> 	raster/r.in.arc
> 	raster/r.in.ascii
> 	raster/r.in.bin
> 	raster/r.in.gdal
> 	raster/r.in.gridatb
> 	raster/r.in.mat
> 	raster/r.in.png
> 	raster/r.in.poly
> 	raster/r.neighbors
> 	raster/r.null
> 	raster/r.proj
> 	raster/r.recode
> 	raster/r.resamp.bspline
> 	raster/r.resamp.filter
> 	raster/r.resamp.interp
> 	raster/r.resamp.rst
> 	raster/r.resamp.stats
> 	raster/r.rescale
> 	raster/r.slope.aspect
> 	raster/r.sun
> 	raster/r.support.stats
> 	raster/r.support
> 	raster/r.surf.idw2
> 	raster/r.to.rast3
> 	raster/r.to.rast3elev
> 	raster/simwe/simlib
> 	raster3d/r3.cross.rast
> 	raster3d/r3.out.vtk
> 	raster3d/r3.to.rast
> In particular, anything using the gpde, lidar or rst libraries should
> be a priority.
> FWIW, the rationale behind the "split window" functionality is to
> avoid having r.resamp.* continually changing the window between the
> input and output resolutions, as this causes the column mapping to be
> regenerated for the input map each time.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
