[GRASS-dev] Rast_set_window() changes in 7.0
Sun Aug 15 01:40:10 EDT 2010
Seth Price wrote:
> I'm getting an error whenever I run r.sun under the latest weekly:
> ERROR: Output window changed while maps are open for write
AFAICT, the Rast_set_window() call is gratuitous; try removing it:
--- raster/r.sun/main.c	(revision 43118)
+++ raster/r.sun/main.c	(working copy)
@@ -1157,8 +1157,6 @@
 	fd12 = Rast_open_fp_new(glob_rad);
-    Rast_set_window(&cellhd);
     if (m != Rast_window_rows())
 	G_fatal_error("OOPS: rows changed from %d to %d", m, Rast_window_rows());
     if (n != Rast_window_cols())
