[GRASS-dev] G65/7 ctypes compilation problem on Enterprise Linux
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Thu Aug 19 08:37:55 EDT 2010
According to Distrowatch ,
http://distrowatch.com/table.php?distribution=redhat , Red Hat 6 has Python
2.6.2.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
-----grass-dev-bounces at lists.osgeo.org wrote: -----
To: Markus Neteler <neteler at osgeo.org>
Sent by: grass-dev-bounces at lists.osgeo.org
Date: 08/18/2010 04:11PM
cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] G65/7 ctypes compilation problem on Enterprise
Linux
Markus,
this is the same problem here - the problem is with python2.4 that is used
as default
and that does not include ctypes so you need to make symlink in grass to
make sure
it looks for python2.6 (which I have also installed) or there may be some
other solution -
You cannot remove python2.4 because it is used for system management.
I did not have time to get it fully resolved yet.
The problem should go away with the next release of RHEL which is in beta
and
should use python 2.6 (I think),
Helena
On Aug 18, 2010, at 3:40 PM, Markus Neteler wrote:
> Hi,
> since Helena mentioned a problem on enterprise Linux, I tried to compile
6.5 on
> Scientific Linux, a RHEL derivate.
> Indeed, I get this problem:
> make[1]: Entering directory
> `/home/neteler/software/grass65_release/lib/python/ctypes'
GISRC=/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc65
GISBASE=/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu
PATH="/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/bin:$PATH"
> PYTHONPATH=""
LD_LIBRARY_PATH="/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/bin:/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/lib::/home/neteler/binaries/lib/"
> LC_ALL=C ./ctypesgen.py --cpp "gcc -E     -DPACKAGE=\""grasslibs"\"
-I/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/include"
> -lgrass_datetime
/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/include/grass/datetime.h
/home/neteler/software/grass65_release/dist.x86_64-unknown-linux-gnu/include/grass/P_datetime.h
> -o date.py
> Traceback (most recent call last):
>  File "./ctypesgen.py", line 36, in ?
>    import ctypesgencore
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/__init__.py",
> line 51, in ?
>    import parser
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/parser/__init__.py",
> line 17, in ?
>    from datacollectingparser import DataCollectingParser
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py",
> line 10, in ?
>    import ctypesparser
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/parser/ctypesparser.py",
> line 15, in ?
>    from cparser import *
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/parser/cparser.py",
> line 19, in ?
>    import preprocessor
>  File
"/home/neteler/software/grass65_release/lib/python/ctypes/ctypesgencore/parser/preprocessor.py",
> line 14, in ?
>    import ctypes
> ImportError: No module named ctypes
> make[1]: *** [date.py] Error 1
> make[1]: Leaving directory
> make: *** [default] Error 2
> I also tried on GRASS 7, same thing.
> SciLin 5.2 provides python2.4.
> A fix would be appreciated.
> Markus
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100819/88f93307/attachment.html
