[GRASS-dev] Re: [GRASS GIS] #1090: Access is denied - r.statistics
GRASS GIS trac at osgeo.org
Thu Jun 17 14:04:15 EDT 2010
 Reporter:  nkale                                 |       Owner:  grass-dev@…
     Type:  defect                                |      Status:  new
 Priority:  normal                                |   Milestone:  6.4.0
Component:  Raster                                |     Version:  6.4.0 RCs
 Keywords:  r.statistics access denied, wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32                                |
Comment(by hamish):
 > Replying to [comment:3 hamish]:
 > > could you give the grass 7 daily snapshot a try?
 Replying to [comment:4 nkale]:
 > That worked.
 ok, good. in a few days once grass6.5 daily snapshots are fixed I might
 ask you to try that.
 > Ran with a slightly smaller dataset (didn't know if the raster
 > format was the same between 6 & 7, so I had to do some lengthy
 > re-importing),
 for now it is the same, but that is likely to change in the future.
 > but I didn't get any errors, and the output map made sense.
 > On the other hand, in 7 I can no longer launch GRASS in MSYS mode,
 > but that's maybe a bug for another ticket.
 Known problem, being worked on.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1090#comment:5>
