[GRASS-dev] problem with r.mapcalc in GRASS 7
Barton Michael Michael.Barton at asu.edu
Fri Jun 25 23:59:05 EDT 2010
On Jun 25, 2010, at 6:34 PM, Glynn Clements wrote:
> Barton Michael wrote:
>> I'm not sure if this is a general issues or something specific to my OS X 10.6.4 build.
>> I just updated and compiled trunk.
>> When I try to use r.mapcalc, I get the following error: ERROR: Unable to load GDAL library
> This is related to the r.external support. GDAL should only be loaded
> on demand, i.e. if you try to open or create a "linked" map.
> You can eliminate the problem by unsetting GDAL_DYNAMIC, e.g.
> 	make GDAL_DYNAMIC= ...
I tried this and got the same error.
Michael
> This causes libraster to be linked against GDAL directly, rather than
> loading it dynamically with dlopen(). However, this might cause other
> problems. GDAL is written in C++, which means that simply loading it
> will cause constructors to be executed.
> FWIW, the list of candidate filenames is:
> 	libgdal.1.1.so
> 	gdal.1.0.so
> 	gdal.so.1.0
> 	libgdal.so.1
> 	libgdal.so
> If GDAL is called something else, or isn't found by the loader (for
> whatever reason), you'll get the error you describe. On Linux, the
> library needs to either be in $LD_LIBRARY_PATH, or in the cache
> created by ldconfig. I'm not familiar with the mechanisms used on OSX.
