[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
GRASS GIS trac at osgeo.org
Tue Mar 16 19:04:51 EDT 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  7.0.0
 Component:  Compiling        |     Version:  svn-trunk
Resolution:                   |    Keywords:  wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:9 glynn]:
 > Replying to [comment:8 glynn]:
 > > > in v.patch, r.patch r.li.patchdensity,r.li.patchnum, that seems
 again to be the problem with UAC and reserverd words for safety in the
 windows world. :o(
 > > That would be my guess.
 > > > that's interesting, because all manifests for all exe-files are
 built.
 > > Ah, but they're all built in one operation at the very end of the
 build process. They need to be built before "<cmd> --html-description" is
 run to generate the HTML documentation.
 > I've changed 7.0 (r41457 and r41458) to build manifests at the same time
 as the executable and (by default) to embed them into the executable.
 However, I only have XP, so I can't test this; please test 7.0 on Vista or
 Win7. It should be possible to build external manifests instead with "make
 MANIFEST=external".
 I've had time for only a very quick test for compiling 7.0 on WinVista32
 (this time only again time for the ./mswindows/osgeo4w/package.sh-
 approach, so the diglib- and gem issue doesn't matter here at the moment,
 and also that installing in C:\OSGeo4W\apps\grass doesn't work; for a very
 basic testing grass7.0 is starting from
 C:\OSGeo4W\usr\src\grass_trunk\bin.i686-pc-mingw32).
 embedding the manifests in the executables works quite well, no compiling
 errors for v.patch, r.patch r.li.patchdensity,r.li.patchnum etc. and no
 working/executing errors for v.patch, r.patch.
 given grass64/65 installed in C:\OSGeo4W\apps\grass and with external
 manifests, i've seen sometimes a r.patch/v.patch-failure because of the
 reserverd-words-for-safety-in-the-windows-world-issue.
 so maybe the embedded manifests would be also an option for grass64?  I
 see that with the embedded manifests the v.patch/r.patch-executables are
 no longer marked with a mswindows-symbol like the executables without any
 manifests/with external manifests. so maybe the approach embedding the
 manifest would be better way?
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:10>
