[GRASS-dev] Re: [GRASS GIS] #1008: WinGrass7 - disable LFS
GRASS GIS trac at osgeo.org
Wed Mar 17 04:59:23 EDT 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  7.0.0
 Component:  Compiling        |     Version:  svn-trunk
Resolution:                   |    Keywords:  wingrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:10 hellik]:
 > embedding the manifests in the executables works quite well, no
 compiling errors for v.patch, r.patch r.li.patchdensity,r.li.patchnum etc.
 and no working/executing errors for v.patch, r.patch.
 > so maybe the embedded manifests would be also an option for grass64?  I
 see that with the embedded manifests the v.patch/r.patch-executables are
 no longer marked with a mswindows-symbol like the executables without any
 manifests/with external manifests. so maybe the approach embedding the
 manifest would be better way?
 It would probably be the better approach, but I don't know how easy it
 would be. The build system has been cleaned up a lot in 7.0; there were
 only a handful of executables which required special treatment, the rest
 being handled automatically by changes to Compile.make. The 6.x Makefiles
 have far more special cases.
 A large part of the problem is that 6.x tries to support older versions of
 GNU make, while 7.0 requires version 3.81. That might not seem like much
 of a constraint, given that 3.81 has been out for nearly four years, but
 both MacOSX and MSys were using 3.79 (nearly ten years old) until fairly
 recently.
 If someone wants to try back-porting the changes to 6.x: for normal
 modules, you would just need to modify the linking rule for
 $(BIN)/$(PGM)$(EXE) in Module.make. But you'll find dozens of programs
 with their own linking commands in their Makefiles (grep for LDFLAGS). You
 can check whether an executable has an embedded manifest by running
 "objdump -h" on it and looking for a ".rsrc" section.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1008#comment:11>
