[GRASS-dev] Re: [GRASS GIS] #1052: Build of 7.0.SVN dont work
GRASS GIS trac at osgeo.org
Fri May 28 16:49:30 EDT 2010
  Reporter:  jeleniste     |       Owner:  martinl
      Type:  defect        |      Status:  assigned
  Priority:  normal        |   Milestone:  7.0.0
 Component:  Packaging     |     Version:  svn-trunk
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:12 martinl]:
 > "GRASS 7.0.svn" (cmd) is working OK. "GRASS 7.0.svn with MSYS" just
 flash and nothing happens.
 > From running MSYS
     gisdbase = gisenv['GISDBASE']
 This may be related to MSys imposing its own $HOME directory. If you start
 GRASS manually from within an existing MSys shell, it should probably use
 MSys' definition of $HOME. If you start the shell from a shortcut or from
 the wxGUI, it's debatable whether it should use MSys' $HOME or Windows'
 %HOMEDRIVE%%HOMEPATH% or Windows' %USERPROFILE%; it all depends upon how "
 Unix-like" the user wants their shell to be.
 Actually, I don't think that we've explicitly discussed the correct
 location for the saved $GISRC file on Windows; arguably, it should go into
 e.g. "%USERPROFILE%\Application Data\GRASS7".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1052#comment:13>
