[GRASS-dev] [GRASS GIS] #1190: Error on compiling GRASS in Windows using osgeo4w
GRASS GIS trac at osgeo.org
Wed Oct 6 13:10:45 EDT 2010
 Reporter:  kimbesson     |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  critical      |   Milestone:  6.4.1
Component:  Installation  |     Version:  6.4.0 RCs
 Keywords:                |    Platform:  MSWindows XP
      Cpu:  Unspecified   |
 As mentioned in:
 http://lists.osgeo.org/pipermail/grass-user/2010-September/057903.html
 and
 http://lists.osgeo.org/pipermail/grass-user/2010-October/058189.html
 and
 http://lists.osgeo.org/pipermail/grass-windows/2010-October/002083.html
 current compilations of GRASS in Windows with OSGEO4w and Msys are getting
 this error in lcurses and lncurses:
 Fri Sep 17 14:02:05 2010: STARTING configure
 checking host system type... i686-pc-mingw32
 checking for gcc... gcc
 checking whether the C compiler (gcc  ) works... yes
 checking whether the C compiler (gcc  ) is a cross-compiler... no
 checking whether we are using GNU C... yes
 checking whether gcc accepts -g... yes
 checking for Cygwin environment... no
 checking for mingw32 environment... yes
 checking for executable suffix... .exe
 checking for full floating-point support... yes
 checking for pwd... /c/mingw/bin/pwd
 checking for source directory... /osgeo4w/usr/src/grass64
 checking for build directory... /osgeo4w/usr/src/grass64
 checking for MacOSX App... no
 checking for MacOSX architectures... no
 checking for MacOSX SDK... no
 checking how to build libraries... shared
 checking for ranlib... ranlib
 checking how to run the C preprocessor... gcc -E
 checking if 64bit support is requested... no
 checking if 64bit Sparc VIS support is requested... no
 checking system version (for dynamic loading)...
 MINGW32_NT-5.2-1.0.11(0.46/3/2)
 checking for dlopen in -ldl... no
 checking for ar... ar
 checking for additional include dirs... /c/OSGeo4W/apps/gdal-16/include
 /c/OSGeo4W/include
 checking for additional library dirs... /c/OSGeo4W/apps/gdal-16/lib
 /c/OSGeo4W/lib
 checking for a BSD compatible install... /c/mingw/bin/install -c
 checking for flex... flex
 checking for yywrap in -lfl... no
 checking for bison... bison -y
 checking for env... env
 checking for perl... no
 checking for ANSI C header files... no
 checking for limits.h... yes
 checking for termio.h... no
 checking for termios.h... no
 checking for unistd.h... yes
 checking for values.h... yes
 checking for f2c.h... no
 checking for g2c.h... no
 checking for sys/ioctl.h... no
 checking for sys/mtio.h... no
 checking for sys/resource.h... no
 checking for sys/time.h... yes
 checking for sys/timeb.h... yes
 checking for sys/types.h... yes
 checking for sys/utsname.h... no
 checking for libintl.h... yes
 checking for iconv.h... yes
 checking for langinfo.h... no
 checking whether time.h and sys/time.h may both be included... yes
 checking for off_t... yes
 checking for uid_t in sys/types.h... no
 checking return type of signal handlers... void
 checking for ftime... no
 checking for gethostname... no
 checking for gettimeofday... no
 checking for lseek... no
 checking for nice... no
 checking for time... no
 checking for uname... no
 checking for seteuid... no
 checking for setpriority... no
 checking for setreuid... no
 checking for setruid... no
 checking for drand48... no
 checking for putenv... no
 checking for setenv... no
 checking for nanosleep... no
 checking whether setpgrp takes no argument... yes
 checking for long long int... yes
 checking for W11... no
 checking for X... disabled
 checking whether to use Curses... yes
 checking for curses.h... yes
 checking curses.h WINDOW structure component... _maxy
 checking for initscr in -lncurses... no
 checking for initscr in -lcurses... no
Ticket URL: <https://trac.osgeo.org/grass/ticket/1190>
