[GRASS-dev] i.landsat.toar to be included in Grass7
Yann Chemin yann.chemin at gmail.com
Wed Oct 13 06:14:46 EDT 2010
Yann Chemin
Senior Spatial Hydrologist
www.icwater.org
On 13/10/2010, at 18:23, Hamish <hamish_b at yahoo.com> wrote:
> Yann wrote:
>> I would like to include i.landsat.toar in GRASS7.
>> I believe this will bring the necessary complement to
>> i.atcorr and the subsequent i.albedo/i.vi/etc that are part
>> of the chain processing of Landsat.
> I'd like to see i.landsat.acca (cloud masks) travel along with
> it too.
+1 for that one too
Do you have a v7 version already ?
>> Is there anybody maintaining it these days?
> Yes, Jorge and I have been working on getting it ready recently,
> https://trac.osgeo.org/grass/log/grass-addons/imagery/i.landsat.toar
Ok will read that one
> The grass7 patch is out of date now- to avoid wasted work I was
> waiting until the grass6 version settled down before recutting
> that.
You mean to include it in v6 too?
>> I would be happy to do the necessary to include it in GRASS
>> 7. In the future, I would also like to remove from
>> GRASS-ADDONS the i.dn2* modules that mostly are included into
>> i.landsat.toar but for the .MTL metadata format of some types
>> of Landsat 5 imagery (I checked the landsat_met.c in
>> i.landsat.toar and believe it is feasible to transfer the .MTL
>> parsing code across eventually).
> as long as functionality is retained and differences between the
> output of the two modules are for known reasons, I don't mind
> i.dn2* being "merged" into i.landsat.toar. I don't think that
> getting the L5 glovis MTL metadata files to read in i.landsat.toar
> will be too hard, as the L7 versions of the same work ok already.
> The process of making it more robust will take a while though, and
> the hardcoded file length stuff in .toar probably has to go away.
If MTL for L7 it should be ok then
I was thinking more about parsing metadata files of other format as
"merging" the modules. The i.dn* are simple dn to rad to reftoa,
nothing i.Landsat.toar cannot do already.
About the fixed length stuff so you have a proposition or should I see
how it comes up along the way?
> thanks,
> Hamish
Thank you Hamish this sounds really good
