[GRASS-dev] wxGUI in GRASS 6.4.1
Markus Metz markus.metz.giswork at googlemail.com
Fri Oct 15 03:31:08 EDT 2010
Michael Barton wrote:
> From: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
> Date: October 14, 2010 6:57:37 PM MST
> To: Martin Landa <landa.martin at gmail.com<mailto:landa.martin at gmail.com>>
> Subject: Re: [GRASS-dev] wxGUI in GRASS 6.4.1
> I do the same thing, but nothing happens. No error, no messages about compiling. Nothing. I've only tried this in 6.5 so far.
As you are using 6.5 here and not 6.4.1, nothing happens probably
because vdigit has been successfully compiled already (it is disabled
only in 6.4).
Have you seen in 6.5 any error messages in the wxGUI command console
after startup that make you think that vdigit is not available, or is
there no Digitize option in the map display?
Markus M
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Oct 14, 2010, at 2:09 PM, Martin Landa wrote:
> Hi,
> 2010/10/14 Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>:
> I tried that and exactly nothing happened. (GRASS 6.5)
> nothing?
> For me
> cd gui/wxpython/vdigit
> make
> works. BTW, install issue fixed in r43922.
> martin
> Martin Landa <landa.martin gmail.com<http://gmail.com>> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
