[GRASS-dev] wxGUI in GRASS 6.4.1
Michael Barton Michael.Barton at asu.edu
Fri Oct 15 11:17:03 EDT 2010
It is not present in 6.5 and I get the following message in the command console:
Vector digitizer not available
Reason: dlopen(/Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc/wxpython/vdigit/_grass6_wxvdigit.so, 2): Library not loaded: /usr/local/lib/wxPython-unicode-2.8.11.0/lib/libwx_macud-2.8.0.dylib
  Referenced from: /Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc/wxpython/vdigit/_grass6_wxvdigit.so
  Reason: Incompatible library version: _grass6_wxvdigit.so requires version 8.0.0 or later, but libwx_macud-2.8.0.dylib provides version 7.0.0
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 15, 2010, at 12:31 AM, Markus Metz wrote:
> Michael Barton wrote:
>> From: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
>> Date: October 14, 2010 6:57:37 PM MST
>> To: Martin Landa <landa.martin at gmail.com<mailto:landa.martin at gmail.com>>
>> Subject: Re: [GRASS-dev] wxGUI in GRASS 6.4.1
>> I do the same thing, but nothing happens. No error, no messages about compiling. Nothing. I've only tried this in 6.5 so far.
> As you are using 6.5 here and not 6.4.1, nothing happens probably
> because vdigit has been successfully compiled already (it is disabled
> only in 6.4).
> Have you seen in 6.5 any error messages in the wxGUI command console
> after startup that make you think that vdigit is not available, or is
> there no Digitize option in the map display?
> Markus M
>> Michael
>> C. Michael Barton
>> On Oct 14, 2010, at 2:09 PM, Martin Landa wrote:
>> Hi,
>> 2010/10/14 Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>:
>> I tried that and exactly nothing happened. (GRASS 6.5)
>> nothing?
>> For me
>> cd gui/wxpython/vdigit
>> make
>> works. BTW, install issue fixed in r43922.
>> martin
>> Martin Landa <landa.martin gmail.com<http://gmail.com>> * http://geo.fsv.cvut.cz/~landa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
