[GRASS-dev] [GRASS GIS] #1201: wingrass
GRASS GIS trac at osgeo.org
Tue Oct 26 04:45:29 EDT 2010
#1201: wingrass
 Reporter:  hellik                 |       Owner:  grass-dev@…
     Type:  enhancement            |      Status:  new
 Priority:  normal                 |   Milestone:  6.4.1
Component:  Packaging              |     Version:  svn-releasebranch64
 Keywords:  wingrass, gdal, proj4  |    Platform:  MSWindows Vista
      Cpu:  All                    |
 from the osgeo4w-ml:
 http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001093.html
 I have updated the gdal-dev, libtiff, and libgeotiff packages from the
 respective trunks' and CVS heads.
 The gdal-dev package is now built with VC9 (Visual Studio 2008 Express).
 This greatest challenge with this proved to be mixups with alloc/free
 between the GDAL GeoTIFF driver's heap, and the libgeotiff heap since GDAL
 is built against the VC9 runtime/heap and libgeotiff is built against the
 VC7.1 runtime/heap.  The fixes are back in GDAL trunk.  This took *way*
 too much time for me to track down, isolate and fix but hopefully we are
 good till next time folks fiddle with the gt_wkt_srs.cpp code without
 realizing this issue.
 There seems to be no problem with building GDAL and it's python bindings
 with VC9 against the same Python we using VC7.1 with before.  Somehow I
 thought there was an issue - but apparently not.  I did have to take care
 to embed manifests.
 Once GDAL 1.8 is released I plan to build a gdal18 package using VC9
 as a step towards reducing my dependence VC7.1 which is now antique,
 and not easily available to others.  At that point I'm also hoping
 we can migrate most packages using GDAL to GDAL 1.8, to try and get out of
 the situation now where the default is ancient (1.5) and some packages
 (MapServer, QGIS) have moved to somewhat newer GDALs.  This puts us in the
 ugly situation where people may end up having to install plugins for
 several versions of GDAL instead of install-once, use everywhere applying
 as I would like.
 I tried to package, and utilize the openjpeg jpeg2000 library but got
 caught up in some details and put it off.  But this is likely our best
 hope for jpeg2000 read/write support that works well for large images
 without depending on proprietary libraries.
 http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001101.html
 hi,
 I've read in the ML "gdal-dev, libtiff and libgeotiff upgraded"
 (http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001093.html)
 from time to time I'm building the "official" wingrass-installer.
 after updating according to "gdal-dev, libtiff and libgeotiff upgraded",
 I can find following updated files/folders in the osgeo4w-stack:
 C:\OSGeo4W\share\proj
 C:\OSGeo4W\share\epsg_csv
 C:\OSGeo4W\share\gdal
 AFAICT the actual wingrass-installers are built against osgeo4w-gdal-15.
 gdal and proj4 are dependencies for grass.
 which of the above mentioned (actualized) files/folders should be
 included in the wingrass-installers and for which above mentioned folders
 should be set GDAL_DATA and PROJ_LIB in order to get proj4 and gdal
 working properly?
 best regards
 Helmut (a little be confused and ...)
 p.s.
 "At that point I'm also hoping we can migrate most packages using GDAL to
 GDAL 1.8, to try and get out of the situation now where the default is
 ancient (1.5) and some packages (MapServer, QGIS) have moved to somewhat
 newer GDALs." ... very appreciated :o)
 http://lists.osgeo.org/pipermail/osgeo4w-dev/2010-October/001102.html
 Helmut,
 They should all be include with wingrass.
 GDAL_DATA=C:\OSGeo4W\share\gdal
 PROJ_LIB=C:\OSGeo4W\share\proj
 GEOTIFF_CSV=C:\OSGeo4W\share\epsg_csv
 AFAIK \share\gdal and \share\epsg_csv isn't included at the moment in the
 wingrass-installer: see GRASS-packager.bat
 (http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
 /GRASS-Packager.bat)
 and GEOTIFF_CSV isn't set by the nsis-installer
 /GRASS-Installer.nsi)
 so wingrass-packaging and installing should be adapted acordingly?
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1201>
