[GRASS-dev] Re: [GRASS-user] Error when importing data in Windows with Python Script
Luis Lisboa luislisboa1975 at gmail.com
Fri Oct 29 11:48:22 EDT 2010
Glynn I decided re-start this issue...
A few emails ago you mentioned this:
I suspect that those in prompt.py should be changed, but I'm not sure
about the others.
I tried to find this file but there is no prompt.py. Is there any
alternative filename?
Thanks
Luis
On Wed, Oct 20, 2010 at 4:29 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Luis Lisboa wrote:
> > > > Ok at utils.py at line 21 I placed:
> > > > import shlex
> > > > and at the bottom of the file (linhe 424) I placed
> > > > def split(s):
> > > >     return shlex.split(s, posix = (sys.platform != "win32"))
> > > > And I still got this error. Did I did something wrong?
> > > It isn't sufficient to add the function; you have to change (some of)
> > > the existing shlex.split() calls to use utils.split() instead.
> > SOrry to bother you and the rest of the people. But when you say that
> > it'sn't enough, you mean that all shlex.split() shall be substituted
> > by utils.split()? is that it?
> Yes.
> Well, not all of them, but the ones which relate to the command
> prompt. Others, e.g. parsing of commands from menudata.xml, shouldn't
> depend upon the platform.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20101029/e428eca3/attachment.html
