[GRASS-dev] v.buffer2 issues
Maris Nartiss maris.gis at gmail.com
Tue Apr 5 03:40:50 EDT 2011
Hello,
I'm totally lost in v.buffer/2 issues. I recompiled v.buffer and
v.buffer2 on 6.5 and was trying out different use cases from trac. All
of them where working fine with v.buffer2. Old v.buffer was still
failing with landcover dataset. I had not tested attribute based
buffering, as it should not be hard to fix buffering by attribute if
in general it works fine.
Can anyone give me sample data that triggers failure of v.buffer2?
Maris.
