[GRASS-dev] v.buffer2 issues
Moritz Lennert mlennert at club.worldonline.be
Tue Apr 5 04:06:56 EDT 2011
On 05/04/11 09:40, Maris Nartiss wrote:
> Hello,
> I'm totally lost in v.buffer/2 issues. I recompiled v.buffer and
> v.buffer2 on 6.5 and was trying out different use cases from trac. All
> of them where working fine with v.buffer2. Old v.buffer was still
> failing with landcover dataset. I had not tested attribute based
> buffering, as it should not be hard to fix buffering by attribute if
> in general it works fine.
AFAICT both now work fine in the cited test cases, but v.buffer is way
faster than v.buffer2. Try buffering the railroads layer in the nc_spm
