[GRASS-dev] can't find : mapdisp_command.py
Massimo Di Stefano massimodisasha at gmail.com
Fri Aug 12 12:03:14 EDT 2011
Hi All,
i'm trying to call a mapdisp canvas from a wxpython script to show a grass-mapdisplay and load a grass rastermap inside it.
My final target is to use the mouse action and capture the coordinates from the mapcanvas, where the user will release the mouse-sx-button.
In order to achieve this target from a wx script,  i was looking in the georeferencer module, but trying to reuse its class :  gcpmapdisp.py
i receive the error message :
no module named mapdisp_command
actually i checked in the grass7.0 source svn (rev.: 47601 ) but i can't find it.
please have you any hints/suggestion/example-code to achieve my target ?
thankYou very much!
--Massimo.
