[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
GRASS GIS trac at osgeo.org
Fri Aug 19 12:33:29 EDT 2011
 Reporter:  hamish                                       |       Owner:  grass-dev@…
     Type:  defect                                       |      Status:  new
 Priority:  critical                                     |   Milestone:  6.4.2
Component:  Vector                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, v.rast.stats, v.db.addcol, v.info  |    Platform:  MSWindows XP
      Cpu:  x86-32                                       |
Comment(by hellik):
 tested with WinGRASS-6.4.SVN-r47756-1-Setup.exe
 there seems to be 2 issues here:
 (1) v.rast.stats seems not to be able to invoke v.db.addcol
 which is in C:\Program Files\GRASS 6.4.SVN\scripts and has
 a wrapper script in C:\Program Files\GRASS 6.4.SVN\bin\v.db.addcol.bat
 Replying to [comment:1 hamish]:
 > Yvan wrote:
 > C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol:
 > command not found
 > ERROR: Cannot continue (problem adding columns).
 (2) v.db.addcol seems not to be able to add a column in windows with
 the dbf-driver, but it's able with the sqlite-driver
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:4>
